PCM Cayenne 2008
I have a 2008 cayenne on which i installed a new GPS Device (BLack Box) that is hooked to the Tuner in the back.
I managed to get it activited on AV channel. the reason i did this because in Jordan we don't have the service to work directly on the built in INav PCM system already available.
Here's the situation; you know how the display disapears once the car moves! I was told that there is a code that unlocks the PCM and allows the screen to display without interrruption.
no code as far as i know but there are plenty of third party devices for about $200 on ebay that do that. just type pcm into ebay search box ebay.de seems to have the most
thanks for the reply.
but the thing is, i wantt o keep the original one installed from the company.
all original stuff stays in place the aftermarket add-on just tricks your PCM into believing the car is not moving
