"Adjustment of Inlet Camshaft in relation to Crankshaft, Bank 2 – Signal Implausible"
No CEL yet. Is this pretty bad or just benign? My 04 CTT drives just fine. Should I take it to the dealer to fix this?
Possible cause of fault
♦ Dirt in oil circuit
♦ Sealing strips on inlet camshaft adjuster faulty
♦ Oil pressure too low
♦ Mechanical fault in intake camshaft adjuster
♦ Magnetic hydraulic valve faulty
Just changed the oil about 400 miles ago with M1 0w-40...
Edited by TopGun2000
