can anyone tell me how to fix my interior light problem . when i take the key from the ignition on my 05 boxster s . the interior light comes on but only for 1 second then goes out . the same when i unlock the car when returning back to the car . ive heard you can set the time via pcm . but i dont have that option
thanks for any help in advance
I would get tested this out with a PIWIS diagnostic/programming tool, you can first try by yourself, to disconnect the battery for a couple of minutes, since the car is a RHD Euro version, disconnect the battery with the ignition on, it will prevent the alarm goes off. After reconnecting the battery, relearn the side windows as mentioned in the manual.
