I need help with my 2000 986 s ,
Its only 35k miles on it but since i Bougth it 6 months ago i had 3 broken accesories belts.
two of those were original porsche , the last one was a aftermarket replacement.
I had cheked the pulleys , they seem to be ok, two months ago i replaced the alternator clutch, blaming the problem on that
Any ideas?
Thks
Eliab
Puerto Rico
Can you describe how the belts are failing? Are they wearing on one side or breaking straight across the width? Any odd wear patterns? If possible post a pic of the broken belt.
They start to wear on the outside , then separate the threads, i will try to get a picture of it
