Not charging, but no warning light either
wtmeyer
I appear to have a problem with the alternator in my 2003 996TT. Voltage gauge is reading below 12V while driving, but the Battery warning light is not illuminated. I put a voltmeter across the battery terminals with the car idling and verified the gauge is reading correctly. Has anyone else seen a charging problem without the warning light turning on? What is the light supposed to tell me? Could this be something other than the alternator? Battery is only 6 months old, bought directly from the dealer.
Good info here: Alternator..... It is a common issue with the alternator. If you have time to try a simple regulator replacement you can used the DIY here: Regulator. And the alternator removal DIY: Alternator DIY
The part# for the alternator is 997-603-012-01, alternate look here: Part# and for the regulator is F 00M 145 350...
