I just replaced the alternator in the 2003 996 C4S with the instructions from the DIY but now I have an error display stating "Drive to the dealer" Oil level indicator failure". The oil level is good and the oil pressure is good. Could I of dislodged a hose or ruined a valve when I was replaceing the alternator? How does the system work - electric / vaccuum?? I can't see any problem.
Edited by steve germany
The system is electric and the sensor is located below the intake manifold, around the middle of the engine block.
You will need to remove the intake manifold to install
a new sensor. You can not bend the sensor or it will
break.
Look for a lose connection. I think it is on the passenger
side of the motor.
Paul
break.
side of the motor.
Paul
Thanks for the replies Gents - I'll dig in this weekend
