Hello fellow Porsche enthusiasts,
I have a strange problem with my 2004 Cayenne S clock. Every time I stop and restart the car, the time shows exactly same. If i adjust the time, it will continue counting time normally, but is I stop, and restart the motor, it goes to same time as it was adjusted... Any suggestions why is this? Annoying.
Be sure the battery is in good condition as it can cause odd issues in these vehicles. There is also a TSB 9110 issued to address a similar fault.
If you have a GPS, the clocks are set on the time zone you set up in the PCM. Make sure your time zone and summer time/winter time is selected/de-selected, as appropriate.
