I'm having trouble removing the tailight unit to replace a broken bulb. I removed the plastic plugs and 2 screws and tried to pull the unit out but can't get it to pop out. Is there a trick to loosen it to remove the assembly?
It's held on two ball sockets that need to be pulled straight out. Do not twist or pull the light at a great angle or you will break the tail light housing. One trick is to use an autobody air bag bladder between the light housing and body to pop the unit off the sockets.
Thanks, I got it out. I wedged a wooden paint stirrer into the lateral part of the housing, that opened up a big enough gap for me to get a good grip of both sides. It took a bit a force but the ball popped out.
