'87 944 na
I want/need to short the brake wear sensor wire harness for any of my brake pad sensors to isolate a problematic harness - and also to turn off the "brake pad" warning light in the instrument cluster.
N.B. this is the bundle of wires upstream of the sensor in the pad - there are plenty of discussions about those sensors, but little about the harness.
One problem is understanding the Porsche service manual diagram (section 97, sheets 3-4). I know the colors in German, but I doubt my conclusion about which wires to connect is correct. e.g. it looks like the front left sensor has a black wire, the FR has a brown/white wire, that both lead to the "front wire harness". so to short both front sensors : connect black to brown/white?
I also do not understand why the sensor - which I figure has two wires - connects to a harness with a lot more wires coming out of it, and the consequence of connecting the wrong wires - e.g. I see connections to the temperature sensor, brake fluid reservoir, etc.
-Bryan
