I just got done with a long drive in my new 991 C2Cab (July 2014 build) using the Navi mode for routing instructions. All of the turn and distance directions are incorrectly given in "yards" rather than "feet", e.g. "...turn in 100 yards", rather than "turn in 100 feet..." - otherwise the Navi/Map works fine. This is true for both the voice announcements as well as the displayed distance. Is this something that a simple PCM setup change can correct or something more involved? How can I find the installed PCM 3.1 software version? What is the latest available version?
Well, I checked the PCM language setting and changed it from "Automatic" to "English - U.S.version" but no help. Did discover the software version to be v 4.51, which is probably the latest...still tinkering with PCM settings...
