Hello
The wife s Cayenne Is misfiring on cyl 5 when idling or coming to a stop on l'y when warm
We turn thé engine off and restart and it Is okay until we come to another stop
Car Is a 2008 180k km
Plugs ,coil , #5 injector , chains ,tensionner were changed
Leaked down numbers were not great on 2 bank ( valves were heavyly carbon cloagged)
Removed thé head and rebuild it
Still the same story
I am really starting to hate those vr6
Any help would be greatly appreciated
Merci
There is specific locking tool used to adjust the timing? Are the vacuum operated butterfly valves inside the intake manifold, and intake ports not damaged, blocked or clogged? Are the valves cleaned and grinding  properly in their seats, valve spring(s) not weak or broken? Compression test done? No air leak at cyl. 5? DTC P0305 should be there for sure, anny other error codes? A diagnostic tool could help a lot as well as an emission test (HC-CO-CO²-O²) at idle and at 3.000 RPM. There are many possibilities, into the engine block itself at a VR6.
