Coolant hose change
Had a puddle when warm, from the drivers side front (coolant leak as discoloured the drive).  Common problem so took the wheel off with it facing as far right as possible, then, If I recall, 7 screws to remove the plastic cover of the inner wheel arch (torxs) Bottom of the 2 pipes were the problem on mine The 2 ends of the pipe means you will need a big bucket to catch all the fluid, There will be a something like a 3mm wire cir-clip that retains the hose, one at each end, make sure it i
