2017 Macan 2.0L Base K&N Air Filter Install
The K&N Filter needed for this install is their P/N E-0660 only 1 is required on the Macan 2.0L base model The Air Filter housing cover is located on the front left of the engine bay (see the attached p/n dia and look for item 2) It is held to the air box it self with 4 star screws #20 loosen and lift the top cover (the screws are captive and wont fall off) Upon removing the cover you will see to the right middle top 2 more PLASTIC Keyed #20 screws/bolts (ITEM 6 IN DIAG). BE V
