What do you guys think?
It was actually pretty easy after cluster removal.
My car is navy.
They didnt have anything tan901ba58c061d59338bbc4f6606e68c00.jpg64a1f1063b32db86f401f11b7a9f161d.jpg
Β
Sent from my SM-G965U using Tapatalk
Β
Β
Blue looks great. Any video tutorial you used to show how to remove the cluster?
It was simple.
Remove steering wheel.
Remove column trim.
Remove cluster.
Remove all screws on back of cluster.
Pop open cluster.
Put on gloves to avoid greasy fingerprints.
Twist and pull clockwise needle to pull off.
Peel bubbly sticker faces off.
Align insert new faces.
Twist and push down counter clockwise to install needles.
Line up needles to start position.
Put it all back together.
Thanks guys.
I just followed instructions for cluster removal.
All the screws on back cluster were removed to get open.
Γ—
Γ—
