Hello. I have a Cayenne 2011 and have changed most of the ecus. I have some questions about the coding procedures.
I need to recode some modules due to other equipment in my car than the donor car. Is there any guides for the long coding? (The old ecu's are defective so it isnt possible to read the coding from them )
I also need adjusting procedure and login codes for: Level control and ABS PSM Steering angle calibration
Does anyone know where to find this?
The tools i have is: Pocom, Vcds, salus and Bosch kts 670 with bosch esi.
Sent fra min SM-A505FN via Tapatalk
