I'm having some problems with the headlights on our '97 986 and having pulled the assemblies out of the vehicle I found the wiring inside was dry brittle and crumbling. Lots of exposed copper, probably caused a short and damaged the lamps.
I have been searching for a replacement loom but cannot find anything close. Everything I find seems to be the full harness that goes 'outside' of the headlight assembly, not the internal wiring. Any idea what name/terms to search for, and where to search. Everything I found was on ebay, nothing OEM new.
For now I've tried to wrap in tape but worse comes to worse I will cut/splice and put new heat shrink over it all. Unless you guys have any better solutions.
The lamps incidentally are aftermarket HID LEDs. I am going to try to replace with OEM bulbs for now. Only the high beam works right now
Cheers
