Nismopowered
Everything posted by Nismopowered
  1. Good idea. Did that tonight when I got home. Couple of turns. They land in the same exact spot. So. Forget the crank. Let's line up the cams. When the cams are lined up the notch on the crank is about 1 inch before the mark on the block. Not sure it jumped teeth or busted cam guide. Not ims. That was done not to long ago and has been fine. Plus it has been driven at least 50 miles at freeway speeds from when I first acted up. Starting to think no way to fix in car. And if I pull it out, well then why not just build the 3.6 engine I have sitting here instead.
  2. Plot thickens. Set TDC. Pulled bank 1 cam plugs. Not straight up and down. Off by just a little bit. Both cams clockwise. Instead of the center of the notch lining up with the seam. The trailing edge lines up with the seam. Even on both cams.
  3. Durametric pro with both cables. San Jose ca
  4. looking for some input? I have a 2005 987s that as I was pulling into the marina pca autocross school this last weekend. would not hold idle with flashing cel. was ok at freeway speeds so I was able to drive it 40 miles home. on the freeway it was a solid cel and drove ok. using durametric 6 I pulled up p0011 p0300 p0306 p0305 p0304. I swapped out the passenger side vario solenoid and reset it runs ok , idles ok. but now I get p0016. tried swapping out passenger side cam position sensor and no help. actual bank 1 cam =-9. to -12. cam deviation is at 20.000 actual bank 2 cam = -0.2--0.5 cam deviation is at 3.4531 ims was done. does not make any funny noises. any help would be great thanks!
