machster
Everything posted by machster
  1. Is it normal for the CEL to light for a few weeks and then go out?
  2. I did install the Azrinc Shrt shifter on ebay. See my post. http://www.renntech.org/forums/index.php?s...amp;hl=machster
  3. What tool is needed for the drain plug and fill plug? Is Mobil synthetic 75/90 ok?
  4. I have a 2001 Boxster. When I use the fog lights my left turn signal does not function. There are no other symptoms that I can see. Is there a relay or something that needs replacing?
  5. If anyone is interested, I have listed on Ebay a Durametric diagnostic tool and software. I used it to reset my airbag light. http://cgi.ebay.com/ebaymotors/ws/eBayISAP...0763&rd=1,1
  6. I noticed that there are few posts about the replacement of the generator in the Boxster forum. After reading the info that was available I went ahead and did the job. I must say that the steps that were posted are accurate except that after loosening and removing the bolts, you must first unseat the rightside of the generator from the U-Shaped metal bolt sleeve by prying gently upward. After this you can then rotate the whole genrator to the right for removal. Hope this helps!
  7. I have a 2001 Boxster. I have the generator loose but will not rotate right to allow for full removal, It does move upward slightly. Does anyone have any tips to free the generator?
  8. I am looking to buy a 2001 Boxster S. It is not equipped with the onboard Computer. My current 2001 Boxster has the computer. How easy would it be to swap cars?
  9. That is a well put together diagram. Thanks for the suggestion.
  10. I have ordered new front and rear pads including sensors from Sunset. I consider myself handy and would like to replace them. Any helpful hints that I can use to make this job easy?
  11. I currently own a 2001 Boxster that has heated power seats and am interested in a 2002 Boxster S. The S has basic seats that are not powered. Can I swap the center console and seats between the cars?
  12. I purchased the Kumho Ecsta ASX for my 2001 Boxster. Front 225/40/18 rear 265/35/18. I have put about 1000 miles on them and am very pleased with the performance and ride. I had Continentals before. I have not noticed any decrease in performance and a boost in ride quality. Also they should last well over 20K unlike the conti's.
  13. I drive my 2001 Boxster like many others, mostly to work and back with a little spirited driving. I dislike the brake dust that I clean weekly. What pads are a good balance of clean, quiet and performance? Do they offer wear indicators?
  14. I installed it yesterday and drove it last night. Both my wife and I like the change. I think it is a little notchy if you drive it hard. It does smooth shift though. It feels a little heavier but with a little time I will get used to it. It is totally different than stock. We used to have to make sure it was in gear before letting off the clutch. Now it goes in immediatly.
  15. See my post. The shifter is great. Just flip the lever around before you install it and it will stand straight up.
  16. I bought and installed the Azrinc Blue short throw kit found on Ebay for 55.00. Made a huge improvement to my 2001 Boxster. After installation the shift knob was way left from center. I think the manufacturer installed the lever backwards. I unscrewed the 1/2" nut and bolt and flipped the lever around. Now the Shifter is perfectly straight. Maybe they do this on purpose so they don't get sued by B&M for knock offs. I would recommend this for any stock shift kit upgrade. Installation took about 1 1/2 hours.
  17. During deceleration while in gear, my 2001 boxster has a strange vibration at about 3k rpms. Higher or lower it is not evident. It doesn't matter what gear i'm in, it always happens when i slow to around 3k. I am not using the brakes when this occurs. Any ideas?
  18. My Coolant Pump and pulley failed and seized. I have pulled the old pump off and would like to flush the entire system of metal and plastic fragments before (if possible) I refill the new coolant. Can anyone step me through the flush and fill process? I cannot find the proceedure in the service manual. Thanks in advance!
  19. I have blown off the pulley on the Coolant pump on my 01 Boxster and lost all the coolant. It also tore up my belt. On a scale of 1 to 10, what is the difficulty of replacing the pump and belt?
  20. Does anyone know how to remove the coolant pump assembly from a 01 boxster? the Pulley has separated from the pump and needs to be replaced.
  21. Is the driver's seat frame lower than the passenger's?When I adjust both seats to the lowest position it seems that the driver's seat is much lower
  22. Has to be done by a dealer. The dealer will need the code from the hang tag that should have come with the remote. If you don't mind me asking, where did you get a new key cut? Thanks for the info. I purchased the car from a used car dealer, and he ordered it on my behalf.
  23. My old key self destructed and I have a new remote entry key that is cut the same but will not start the car. How do I marry the new key to the car?
  24. On a scale of 1 to 10, does anyone know the difficulty of installation on a 2001 Boxster?
