mrmagoo
About mrmagoo
    Camrose, Alberta
    1979 Porsche boxster
mrmagoo's Achievements
  1. Try 9579 Tried that code, doesn't work, any other options? Thanks D Did you follow the procedure in the Lost Radio Code FAQ? If not, please do so and then re-submit the correct serial number. Radio is out of the car, number came off the deck. Guess next step is call Porsche and see if they can recover the code or reset with a new code? Thanks D They can not reset it and they will likely charge you find the serial number and code. Why not put it back in the car (briefly) to get teh displayed serial number - then I can get the code for you. Will do and get back to you. Thanks D
  2. Try 9579 Tried that code, doesn't work, any other options? Thanks D Did you follow the procedure in the Lost Radio Code FAQ? If not, please do so and then re-submit the correct serial number. Radio is out of the car, number came off the deck. Guess next step is call Porsche and see if they can recover the code or reset with a new code? Thanks D
  3. Try 9579 Tried that code, doesn't work, any other options? Thanks D
  4. Loren, I have 1997 boxster , battery disconnect and lost radio code Becker CR210 Model BE 2192 Radio Serial # U5005105 (looks like that) Can you suggest a code? thanks D
