BobSC
Everything posted by BobSC
  1. Try 0109 Tried it, but it did not work. Entered the code and then the asterisks just came back. Is there a button that needs to be pressed after entering the code (the manual does not say so)? Thanks for helping! No, just entering the code should start the radio working on a CDR-220. Did you use the procedure in the Lost Radio Code FAQ to get your serial number? If not, then please read that and follow the procedure and re-post the correct serial number here. Hi Loren. Yes, we did use the procedure from the FAQ to get the serial number. Thanks for the help. See below: Loren, Any additional thoughts? Thanks!
  2. Try 0109 Tried it, but it did not work. Entered the code and then the asterisks just came back. Is there a button that needs to be pressed after entering the code (the manual does not say so)? Thanks for helping! No, just entering the code should start the radio working on a CDR-220. Did you use the procedure in the Lost Radio Code FAQ to get your serial number? If not, then please read that and follow the procedure and re-post the correct serial number here. Hi Loren. Yes, we did use the procedure from the FAQ to get the serial number. Thanks for the help. See below:
  3. Try 0109 Tried it, but it did not work. Entered the code and then the asterisks just came back. Is there a button that needs to be pressed after entering the code (the manual does not say so)? Thanks for helping!
  4. Have a 1999 Boxster. Had to replace the battery the other day. Need the unlock code for the CDR-220. The serial# is X5017740. Thanks!
