pocholo1968
Everything posted by pocholo1968
  1. I check compression on all cylinders and 200 psi were all even and I did before starting. I still change the camshaft sensor could exchange it with another bank?then will be fail the other bank.
  2. Hello everyone . As you'll see I'm new to the forum and introduce myself , I live in Florida and have a boxster 987 2006 to buy with a breakdown of lack of compression for open valves do not closed .Repair heads and I have the same problem as the colleague start theme , failure P0018 faulty cylinders 4,5 and 6 . I checked the timming and is correct . I wonder what was the solution he found his colleague because the post is not closed with the solution. apologies for the English and I write with a translator Any help is appreciated in advance .
