pjoshguerra
    Tampa, FL
    Porsche Boxter 986 1996
pjoshguerra's Achievements
  1. Thank you very much Loren!!! it worked!!
  2. Try 0979 Oh sorry I did another comment, just to let you know that it didn't worked, the 0979 code Did you follow the procedure to get your serial number in the Lost Radio Code FAQ? Please do so and re-submit. Try 0979 Oh sorry I did another comment, just to let you know that it didn't worked, the 0979 code Did you follow the procedure to get your serial number in the Lost Radio Code FAQ? Please do so and re-submit. Hi Loren the SN: T5002155 I will thank you a lot for you help for the code Thank you So just to make sure you have the info the instructions require : It is a Porsche Boxster 986, 1997 Becker PR-VERS: R 1996 SERIAL N.: T5002155 Thank you very much, and sorry for the amount of comments!
  3. Try 0979 Oh sorry I did another comment, just to let you know that it didn't worked, the 0979 code Did you follow the procedure to get your serial number in the Lost Radio Code FAQ? Please do so and re-submit. Try 0979 Oh sorry I did another comment, just to let you know that it didn't worked, the 0979 code Did you follow the procedure to get your serial number in the Lost Radio Code FAQ? Please do so and re-submit. Hi Loren the SN: T5002155 I will thank you a lot for you help for the code Thank you
  4. Try 0979 Oh sorry I did another comment, just to let you know that it didn't worked, the 0979 code
  5. HI there Loren I just tried it 0979 and it didn't work, you know if there is something wrong with it. Because I followed the instruction you gave. Thanks
  6. HI there Loren, I hoping you can help me find my radio code I have a Porsche Boxster 986 1997 Serial N. VS600894 CR-210 by the way the screen says "WAIT", I guess it is because I tried too many times and failed. Thanks!
