lukecufc
Everything posted by lukecufc
  1. Hi I could really do with some help after no radio for 2 months! Type: cdr22 model no.: be6621 seriel number: 15005215 thank you very much in advance
  2. Thanks, that was the code. I actually found the little grey card with the number on after I posted this. Annoyingly I haven't been able to locate the other car's. What do I do about getting the code for this one?
  3. Hi could you please provide radio codes for the following cdr22s? 1. Serial number x5017662 2. Serial number 15005215 Many thanks Luke
  4. Thanks, had them before so I know what they're like. Cheers anyway
  5. Thank you! Basically it's a car I'm looking to buy and these lights are illuminated and apparently it needs disks and pads, so he has said this is why the lights are on. Apparently the car has sat for 6 months so I imagine the battery has got low at some point (he told me he'd need to trickle charge the battery before viewing) I have a small fault reader code. What should I do?
  6. Would the ABS light come on as well as the brake pad wear light if the brake pads were simply low? Or would the ABS light illumination be due to another issue? Thanks
