Fulvio Marco
Everything posted by Fulvio Marco
  1. Ok.. i'm so sad.. my mechanic changed the 2 valves but the error come up again!!?
  2. Is this the location of One of the 2 valves?picture n. 4 7pp906270 .. engine compartement?
  3. One more question.. valve n. 23.. is It accessibile from the engine?
  4. Ok thank you.. is It possible to do this job without lift?do you have the procedure?
  5. Oh my god!is it inside the transmission? I think it's outside.. Can you clarify me?
  6. Okay! Which is the parte Number? do you have a diagram?only to understand the location of this valve.. Thank you:-) PS is It possibile the valves are two?
  7. Hi!i drive boxster 986 1998 2.5 tiptronic.. (tiptronic atf and filter changed 1 year ago). now i have a strange problem only when car engine is in temperature. D or P flash with 4th gear.. i can't feel any difference in normal driving.. automatic and semiautomatic works perfectly and from 1 to 5th gear are ok. A generic dealer attached diagnosis and there's a code in tiptronic that is like "cooler intercepting valve" (i'm translating from italian!) What do you think??
