tightbox
Everything posted by tightbox
  1. Jimmy, I would love yours if you get Eric's crest. My boxster has a missing steering wheel crest!
  2. Any pictures/better description of this failure and fix? I have a similar problem with my car. It cut out while driving, and I eventually found fuse C1 blown. Replaced that and it started and idled fine for 20+ minutes. Shut it off, and it hasn't restarted since. Tested wiring between fuse C1 and DME, which was fine. Swapped multiple relays, etc. Thanks for any further assistance!
  3. Same exact problems here. P0733 and P0744 (DTC 73, 74) showing on OBDII scan. What I have done so far: 2 full fluid changes (first one w/ new filter) Swapped entire valve body and solenoid pack from 12k mile old trans Cleared codes, rechecked; same codes came up. Still same problem as OP. 1st and 2nd engage properly, third just slips until redline - won't engage AT ALL!!! Anything else I should try/check before biting the bullet and having the rest of the other (12k mile) tip trans installed? This is really discouraging as my car only has 52k on the odo. I don't drive it that hard, do I? EDIT: just tried running it with the MAF disconnected - no change
