grc0456
Everything posted by grc0456
  1. Looks like Savanna Beige to me. Sent from my iPhone using Tapatalk
  2. Jumper should work without battery, although I have no experience. Look behind your tow hook for the wire, as many relocated it there for ease of access. Sent from my iPhone using Tapatalk
  3. Sorry, I’m no help. But, when I purchased my ‘03 Base, the radio/CD player was not working. I sent the head unit and amp off to Becker in NJ for bench testing. The head was OK, but the amp no good. They rebuilt it for about $300, if I recall. These MOST systems are tricky, I guess. Sent from my iPhone using Tapatalk
  4. You likely need to replace one of your push rod ball joints. They wear out with age, or broke due to some sort of tension. Replace with plastic - not metal - part. Plastic is designed to break if undue tension is applied thereby saving you from destroying the top or motor. There is a seller from MN, l believe, on eBay. Get two and you’ll have a spare. Sent from my iPhone using Tapatalk
  5. http://www.pelicanparts.com/catalog/SuperCat/1051/POR_1051_WATRAD_pg1.htm OEM part is $27.00 Sent from my iPad using Tapatalk
