alstarz88
Everything posted by alstarz88
  1. i only need the wiring loom, instrument cluster, selector, and steering wheel. i got the gearbox already with torque converter and my engine is sweet as a nut
  2. just out of interest does anyone know if it is possible to upgrade the intrument cluster to the facelift one and whats involved in this
  3. when i bought the car and drove it home after being valeted the airbag light was on permanently on all the way but after the car dried out it was fine for 10 months now it has started again on my jouney to work today it kept coming on and going off does anyone know what can cause this.
  4. Not yet im collecting the bits together got the gearbox and torque converter on ebay cheap but i thought i would need a full wiring harness. how does the car control the throttle when changing gear.
  5. Do all tiptronic boxsters have E Gas i would of thought that with the way tiptronic works you wouldn't be able to have cable driven accelerators. i am planning on retrofitting tiptronic to my 98 2.5 as i picked up the gearbox really cheap. when i'm doing this i am planning on fitting cruise control and maybe if possible upgrade the electrics to face lift as i will have to replace the wiring loom now i have a few questions will a facelift wiring loom plug into the gearbox. do i need E Gas Is there anything i need to look out for 98 boxster 2.5 man
  6. assuming i did want to upgrade for cosmetic reasons is it just a case of discs and calipers or do you need to replace the hubs
  7. i have seen alot of owners who have upgraded there brakes to cross drilled S ones does anyone know wether they just swap on or do you have to change the hubs etc
  8. i have a 2.5 boxster and enjoy driving it the way there supposed to be driven. i have recently noticed flat spots high in the rev range and they are getting worse has anyone got any ideas i think it might be fuel related any thoughts
  9. Then how come in every posting about the issue somebody says that it is most likely a cylinder sleeve? because that is a symptom of that fault and it was common with the early 996 engines bt rare in the boxsters the sleeves can be fixed IF it is that autofarm can do that alternatively if you do want to replace your engine with a bigger one all the 996 engines will fit with only slight modifications. there is an instruction manual available on this site for it.
