Andy Francke
Everything posted by Andy Francke
  1. I recently went through this with a new (to me) 2004 996tt. Bottom line is that the headlight switch needed replacing - once I got it out and shook it, it made noises like a maraca from all the plastic that had disintegrated inside - but it wasn't the main problem. Instead, the insulation on the wiring inside the headlamp assemblies was crumbling and I believe shorting out. Take a look and remedy if so (rewrap wires or replace). Be very careful when replacing headlamp assemblies into car that you do not bend pins on the electrical connector - check that none are bent already.
