z064ddle
Everything posted by z064ddle
  1. After some further inspection of the old sensor, I do see some scuff marks on the metal part of the senor. Not sure if the trigger wheel finger is touching it and caused that mark. Please see photos. I did measured the terminals on the sensor connector of the drivers' side. It's 6.xx VDC between Red and Black. It's 11.xx VDC between Red and the 3rd wire.
  2. I replaced the sensor on the driver's side, but the issue remains. Car runs great with good acceleration and no noise. I unplugged driver's side camshaft position sensor connector and it didn't make any difference. I unplugged the passenger side sensor and car won't start and threw additional code P0348. Plugged back the 3-wire connector to the sensor for passenger side, car starts fine. Does anyone know how the 2 Cam sensors work together? Thanks....
  3. That could be my issue. I replaced the sensor on the passenger side. The CEL came on after I replaced the passenger side valve cover gasket. Maybe that was just a coincident. Thanks for the tip Loren. Let me change out the driver side sensor now.
  4. Long story short, I replaced the valve cover gasket on both sides on my 2006 Cayenne S due to some leaks in the spark plugs holes (noticed that when I was changing out the spark plugs to fix some misfire issue). The driver side went smooth with no problem. The passenger side took a little longer due to more things to remove and little tighter space. After the gasket was replaced, there was a Check Engine Light. I went out to Autozone and they did a scan for me, it showed a P0346 (Camshaft position sensor 'A' circuit range/performance bank 2) I removed the camshaft position sensor and inspected it, everything seems to be fine. I bought a Foxwell NT520 Porsche scanner and cleared the code. The check engine light came back the next day with the same code P0346. I bought a new sensor and replaced the old one. Cleared the code, start engine, but CEL came back on after I rev the engine a few times. The car runs great with no issues. Is there something internal that I could have touched while installing the valve cover? I know that there is a Camshaft sensor trigger wheel that has some fingers, but I wouldn't think they could bend that easy. Please let me know if you have any idea what could caused this problem. I hate to take out the valve cover again, but afraid I may have to in order to inspect the internals. I did a live data test from the NT520 and Camshaft Deviation bank 2 is blank. It's -2.00 for bank 1. Looks like it's not reading anything at all.
