Dennis Bergman
Everything posted by Dennis Bergman
  1. does anyone have a wiring diagram for the convertible top? 987.2 boxster. ive narrowed the issue down to (pretty sure) being between the relays tray and actual switch in the center console. ive gone as far as cut the green wire that goes to the top motor under clam shell and put 12v to it, it started to work. ive checked the relays and swapped them aswell and still nothing. ive tested the switch in the center and the green and brown wire switch while pulling the switch up from positive to negative like it should. which make me think its somewhere in between the switch and the relay tray. in process of tearing apart middle console, i add power from right before the relays directly to the wire and it works fine just doesnt seem to get the connection when the switch is triggered.
