Ironken
Everything posted by Ironken
  1. Thank you! This saved me $$$. We had similar symptoms with our 1999 996 convertible. The car would stall when stopped after the engine was warm. Replaced the fuel pump relay, fuel filter, and fuel pump before stumbling upon this forum. The shop and mobile mechanics were stumped. After no luck with replacing the fuel pump, I had them replace the crankshaft position sensor and the problem is solved!
  2. If you are having these symptoms, replace the crankshaft position sensor! This forum saved me. My 1999 996 convertible stalled at a light while my wife was driving it. It would not start and she had it pushed to a nearby gas station. An hour or so later, just as the tow truck arrived, the car started back up. We drove it to a shop who could not find anything wrong with the car. The car was not throwing any error codes and they drove it around for a bit with no stalls. They did not charge us, but did not fix anything either. This made me nervous as I doubted that it was a one time occurrence. The next day after picking our son up, the car stalls and dies on me while stopped/turning onto our street. I had a bad feeling and it came true. Very scary to stall while trying to cross a road with on coming traffic. Since the shop did not find anything, we resorted to searching the web for some solutions. The signs pointed to a bad fuel pump or fuel pump relay. I replaced the fuel pump relay myself, the problem still existed as I could now drive a few loops around our street and the car would stall when I stopped in my driveway. After a few hours, the car would start right back up. We called a mobile mechanic to have the fuel pump replaced. He wanted to try the fuel filter first as it is a cheaper fix. That did nothing. Next, we replaced the fuel pump. After replacing the fuel pump, we drove the car a few loops around our street, pulled into the driveway, let the car sit. Then we drove in reverse for another loop around the street and the car stalls and will not start. We pushed it back into the driveway and then it would start a few hours later. The mechanic was stumped. At this point we were losing hope until I stumbled upon this forum. After reading all the posts, the symptoms were the same. After the car would get warm, it would stall out and then would not start again until it was cool. I called the mobile mechanic and he was not sure it would be the crankshaft position sensor and did not want me just throwing money at the car. I told him that I found this forum and others had the same exact problems we were having. Others tried replacing the fuel pump, etc. but the car would still stall when hot. They replaced the crankshaft position sensor and voila, problem solved. He said OK and replaced our crankshaft position sensor. We drove the car around our street three times, let it run in the driveway, drove it around another time and it did not stall! Today, we drove the car to during rush hour traffic with no stalling. Problem solved! Thank you so much for sharing this information on this forum as we and the mechanics were starting to lose hope. I love this car and it has been amazing. This was the first real issue we had with it and we want to gain trust in the car again. If anything, the car does run a little nicer, I am sure all this ethanol gas is not good for her.
