johnsosn
Everything posted by johnsosn
  1. Mine needed 6 new ones @ 7000miles a little extreme. My opc said that Beru have just changed the material they're made from.
  2. I agree with you, but it is another option. Plus, I never suggested it was "just an ECU (proper term is DME) and filter thing". The dealership does the following: carbon fibre air filter housing revised, race tuned camshaft & cylinder heads different exhaust manifold Sport exhaust Factory warranty 381 HP 306 lb/ft torque 4.4 0-60 $18,699 The x51 doesn't use new camshafts.It re-uses the old ones.
  3. Thankyou Loren. Appreciated. Simon
  4. Hi Loren, I wonder if you can help? I've been searching the forum, including TSB's and cannot find the rveccomended manual gearbox oils for the 997. Is it the same as the 996? I wanted to change mine today. Many thanks Simon
  5. Unforunately this info must be wrong. You cant have 1 ignition in range 3 then more in 4 & 5.
  6. Hi Loren I wonder if you can help me? Do you have access to porsche workshop manuals? I need two procedures if possible. workshop manual 272219 Removing and installing three-phase generator, and workshop manual 873419 Removing and installing air-conditioning compressor. Any help would be appreciated. Many thanks Simon
  7. Thankyou very much Loren. You're a Star. Much appreciated. Simon
  8. Hi, Would anyone have access to the torque settings for the cat bolts on a 2005 997s? Many thanks in advance Simon
  9. Hi, I'd like to change the speakers in my 997. I have the standard system (no Bose). Does anyone know the sizes of the standard speakers? Also are there any good makes that will fit straight in? Many thanks Simon
  10. Thankyou for taking the time to check that Loren. Much appreciated. Best regards Simon
  11. Thanks for replying Loren. It's a 2005. Many thanks Simon
  12. I'm lookin for the part numbers for 997s cats. If anyone could help, it would be appreciated. Many thanks Simon
  13. Hi, I phoned Lancasters (opc) and asked them who they used. They done a very good job and all in one day.
  14. Hi Guys, Anyone know if this works for 997? Regards Simon
