Kkw1027
    Sarasota, FL
    2009 Boxster
558 profile views
Kkw1027's Achievements
  1. 2009 Boxster. With both pushrods removed and both clamshell rods removed from both sides, top should be in full manual mode. Half way up, the top stops. The framework will not extend fully. Up, down.....up, down...no problem. But only halfway up. Do I have to remove the canvas top to access the frame?
  2. I can reconnect end caps. Top will close perfectly in motorized mode. And then will open just fine until about halfway up. The top is catching on something. Appears to be on the right side. Here is where the pushrod end caps broke.
  3. In manual mode, push rod end caps disconnected, top will only go about halfway up. Clamshell works perfectly.
