HarryRhee
    Temecula
    Cayenne
HarryRhee's Achievements
  1. On my Porsche Cayenne 2009 GTS got code P2404. After reading all the blogs, replaced the vacuum pump. It was the correct decision. Code went away and car runs better. You can change yourself if you have time and patience. Pump costs $160 online. Tools you'll need is small ratchet (https://www.amazon.com/Drive-Dual-Stubby-Ratchet-Handle/dp/B009TA14P2), E10 socket, string (attached to ratchet cause you'll drop it trying to squeeze it in position so easy to recover if you drop it), plier (disconnect the hoses). Pelican Parts website has good instructions on pump removal. Don't need to remove the intake manifold if you can squeeze hands where vacuum pump is located. Maybe an hour job.
