sprout99
    Durham, UK
    Other
    Porsche 996 C2, Mk2 VW Golf G60, Mk7 VW Golf GTi, VW california SE
  • Future cars
    Porsche 997 C2S
    CLA45 AMG SHOOTING BRAKE, MERCEDES C350, BMW 330D
sprout99's Achievements
  1. Dont totally agree. I bought one with a two year warranty. It fits just fine. It took a while to get it working because the window glass has to be adjusted right before the mech can be set up. Once you have slider end stops adjusted the cable tension needs a fine tune. To the OP. The microswitch in door handles is supposed to send a signal to drop glass Check they are working correctly Sadly it will be a door trim off for this
  2. I bought a none genuine part as I needed it sorting In a hurry so the adjustment maybe different. The oem equivalent part has cable tensioning screws in bottom corners. I think porsche version uses some retaining clips that allow the cable to be adjusted either side of the drive gear. If it works leave it. My cable snapped just after I'd arrived at an airport at the start of a business trip.
  3. I've changed a window regulator recently..... Horrible job! Fiddly getting it set up right. The cable tension does indeed need to be right for the window to drop.
  4. Pipe done, Evap canister and fuel filler needs to be removed. The smaller AC pipe needs to be disconnected and It's I fiddle to get pipe out. Found a split o ring but had planned to replace anyway. Took about 3 hours in total. Changing a window regulator is way more horrible to do as a comparison
  5. Hi. The system has emptied itself through a hole in pipe caused by a bad mechanic jacking it up sometime previous to me owning it. I noticed it had a wet patch on the pipe a while back when I had it on a lift sorting out the exhaust seams. But it dumped a load of PAG oil with green dye on driveway last week. I dont believe I need bumper off just wheel and arch liner as the pipe union is in scuttle panel area not near the condensers Just don't know if I need to remove the evap cannister and fuel filler. I think defo the first part.
  6. Mine is leaking from the damaged suction pipe Next to front jacking point. Is swapping pipe easy? Thanks Ian
