Jdw1222
Everything posted by Jdw1222
  1. 2014 Cayenne -V6 For the last week the car has been flashing low coolant level and the temp gauge pegs for maybe 10-15 seconds when we first start the engine. Obviously a false reading. Coolant level appears to be fine. not sure why its getting both a low coolant and high temp as I would think these are 2 different sensors. after this happens the temp reading appears to go back to normal and doesn't have any other warning while driving, but seems to happen every time we start the car. ANy thoughts?
  2. Anyone added a remote start themselves? Is there a plug and play kit or any easy way to add a remote start to a 2014 cayenne platinum?
  3. Got transfer cAse fluid changed. Used the ravenel synthetic fluid. old fluid was definitely black.
  4. Picked up a 2014 platinum (v6)with 60,000 miles looking to do some routine maintenance have seen the post on transfer cases so ordered some ravenel tc fluid and plan to do the change soon. what should I use on plug threads when reinstalling? also going to do oil change and brakes. do I need a new drain plug for the oil change or possibly just a washer or can I reuse the plug? brakes/ getting some squealing from the front. According to the maintenance records it is due for brakes. I just ordered front. I watched a couple videos and feel good about install, but confirming I need new wear sensors? Is it likely the rears need replacing also? Every other vehicle I have owned the fronts always wore out quicker but saw a bunch of porsche owners doing front and rear at same intervals thanks!
