Randy Via
Everything posted by Randy Via
  1. 2012 Door preset switches don't light up except on the off button, and cannot SET new setting, if I push it goes to a different setting and I can't change it.... anyone know a fix or what the issues is ?? Thanks
  2. Replaced Serpentine belt, takes about 4 minutes--piece of cake!! Tensioner was leaking, pulled that off, 10 minutes cleaning area up, installed New Tensioner.....2 bolts.....all easy. Jump in !!!
  3. Yep....standard checks.....OK.....Thank you sir !!
  4. Great info.....thanx. Is there anything else that should be replaced while in there ?
  5. Has anyone replaced their Serpentine belt ? Good tutorial's out there, but want to know if anything else should be replaced at the same time ? Tensioner ? Pulleys ? Bolts ? I bought a '12 Panamera 4 and it only has 69K so I'm going thru and changing most items for up to date maintenance. Plugs, cabin filter, air filter, oil/filter, power steering reservoir. Want to do the belt and tranny next. I also have an '85 928 S so I know when you get in to something, there's always something else that needs changed...so want to have all the parts when starting. Thanx
  6. Yep....the tutorials are great.....PO did not unhook the right headlight washer T and it was broken when I got in there to change my filter. I "Shoe Goo" it back together and clamped it and it was very strong, put it in and works fine....I think the part was $35. also what I did was hook a small rope to the left side bumper strung overhead off a rafter and let it swing out and not drop but easily was out of the way to do the work. Not a hard job.....
