patrick hebert
    Canada
    Porsche 996 C2
patrick hebert's Achievements
  1. Just to make sure. 1- that's means its not a real issue. the dash indicate wrong information but probably the real pressure is good? ( but i could double check with test pressure). just make sure i could continue to drive 😉 2- the red light low oil pressure in dashboard is directly linked with the arrow? that s appears only on idle when 0 bar showed (temperature more 180 and on idle). so this one also is wrong information (potentially) so, i will go to fix it, but want to make sure i could continue to ride thanks
  2. someone resolved issue? I have same issue. cold 4,5 bar and slowly, when going warm, on idle uniquely, little bit less than 1 bar on idle. no noise or anything special oli level good so pretty same you describe. it was the sender unit, oil pump, worst??
