Tony Heindel
Everything posted by Tony Heindel
  1. yes i have a 2006 Porsche cayenne and i am going throw hell with it but i got the same thing the oil level monitoring failure and the psm as well i have changed the oil and filter i have changed all the brakes and were Sencers and it won't start when it says to press the brake and when you do nothing happens thought the brake switch was bad but the brake light work when you press them down and also when you turn the key the shifter can move without pressing the brake and when i hook up my odb2 scanner it says link error i Cheak all fuses they was good the ecm relay tested it and its good but when you turn the key it doesn't click to run ecm but all so when you turn key on the cooling fans will kick on and run i checked the wires that run under the drivers feet under the mat wires looked good and something i seen when you turn the key on and when the shifter can move freely the indicator for the gears and what position the 1throw 6 are not highlighted but the p r n d symbols are all highlighted you turn the key and it says to press the brake but it won't turn over any thought would be very Mutch apricated love the ride but dam
