Jason Morris
Everything posted by Jason Morris
  1. Similar position here, but using Durametric Pro. Did you ever discover what the code is that you need, and if it is only the engine module that needs updating? I show 00133 ATM which I know is 00/steel springs/auto transmission, but I am struggling to get any further.
  2. Well, I have followed an excellent guide to DIY fitment of the cruise control stalk and associated wiring. All I need to do now is code the **** thing in. This is where I am struggling. I have purchased the Durametric Pro kit, but have absolutely no idea where I am going after that. I can view and amend codes for all installed modules, but have no idea which modules or codes I need to amend. Research indicates that it is only the engine code that needs changing. Does anyone know if this is correct, or if I also need to change Gateway and / or instrument cluster modules? Bonus points if you know which codes I need to input. For example, under the engine module I am showing code 00133. I know that the 13 signifies steel spring suspension, and the three suffix is for auto transmission, so I suspect it is the leading zeroes that would need changing for cruise control, but what on Earth should I input? TIA
