Dukeblue
Everything posted by Dukeblue
  1. It seems to be a problem with the temperature - & + buttons. The temperature doesn’t go up and down like it should it seems to jump instead of going up 0.1 0C with each press. This happened just after I cleaned the unit with window cleaner!
  2. Has anyone had the same problem with their climate control display, where the segments randomly disappear. If so is there a fix?
  3. Thank you so much, the code worked
  4. Hi, can anyone help me find my radio code, I disconnected the battery to do some work on a micro switch and I haven’t got the code to put back into my CDR 22 serial 25005877 type 4467 Thank you in advance.
