Andrew Pudimott
Everything posted by Andrew Pudimott
  1. Sometimes things are just this dumb. Turns out someone had installed what looks like possibly some type of remote starter or something like that? They tucked the wiring under the dash. The secondary ground for that was tucked under the dash which caused the intermittent starting issues. Last week, I found this wiring under the dash and removed it not thinking anything of it: Notice the ring terminal that was mostly broken Last week I removed this wire almost completely. It ran from the front of the car to the rear and was spliced in near the relay block. Turns out it was connected to the ground wire for the starting circuit. Yellow/purple wire with red stripes The genius who spliced into this wire used speaker wire. I knew last week that something wasn’t right so I left a bunch of that speaker wire behind. While going through the diagnostic at the advice of an independent tech, I started thinking that the jumbled up mess of black wiring likely was the culprit. I confirmed that the relay circuit ground, 85, was the issue by using a multimeter. I got zero volts on the 85/86 circuit with my wife turning the key. Big thanks to the tech who guided me on that. I now have a better understanding on relays. Once I confirmed the 85/86 circuit was the issue, I figured the speaker wire was likely the ground in that jumbled wiring mess so I twisted the two speaker wire ends together and connected them to a ground Car started after this point so I removed the speaker wire and butt connectors then reconnected the ground wire to its original form and put everything back together. Getting my hands in there with barely any slack was a huge challenge, especially since I didn’t want to pull apart all of the cabrio guts. Bad news however, the cabrio window cracked from it being so old and cold out. Special thanks to Loren and the tech (not sure if he wants his name mentioned) who helped me offline. Now to the cabrio top, but at least the car starts and runs!
  2. I checked the immobilizer box, but it was located under the driver’s seat. Under the passenger seat was just a point of contact for some grounded wires: . I did pull the immobilizer from under the driver’s seat and pulled it apart. It is perfectly clean: I also installed a new ignition switch. I knew that wasn’t going to help, but I figured I would mention it. To recap: Car does not start unless I install a jumper wire and bypass the relay. The battery is charged. There is no voltage drop between the battery and the post in the engine compartment. The ignition switch was replaced, but that was totally unnecessary. What’s next?
  3. Today, I checked voltage at the battery and also at the post in the engine compartment. There is no voltage drop noted. Note, I had just taken the battery off of the charger and measured the voltage in the engine compartment first which will explain the higher voltage coming from the engine compartment. Yes, the charger was off although still connected. ….And, the car did start again today with the relay bypassed…
  4. HI, I previously reported that my starting issue was solved. It’s not, and now the car won’t start unless the relay is bypassed. I originally swapped out the starter relay, and same problem came back as evidenced in the video. I purchased an aftermarket relay and installed it. That worked for a few days, and then stopped working. Now, I can only get the car to start if I bypass the relay. I thought if bypassed the relay, then a replacement relay would be the solution, but that did not work. Where should I go from here? IMG_3505.mov Aftermarket relay below: Car starts when the relay is bypassed: Where should I go from here?
  5. Hi, Thanks for the input. Looks like you may be from PA, do you have any transmission shops you would recommend? The Regulator looks easy enough to swap out, but my guess is a run of the mill shop would just recommend swapping out the whole valve body. I want someone whom I can have an honest conversation with. If they’re going to be in the transmission, they might as well swap out the #4 Pressure regulator and the torque converter plus check all wiring connections in the valve body. The kit on FCP Euro includes all of the solenoids/regulators so I would probably just have them swap everything out (or do it myself). My guess is a transmission shop would be able to diagnose all of the problems you mentioned and discern if it’s the regulator or the torque converter. That said, there are no drivability issues right now, and the car is not a trailer queen so I’d be inclined to drive a reasonable distance to a specialty transmission shop. Any suggestions?
  6. Hi, New to the forum, but not new to classic cars, DIY mechanic projects, etc. I’ll give a brief history of the car I bought which is throwing a P0740 code. I have read all of the previous discussions on this topic both here and on Rennlist, but I still don’t see a good diagnostic path or solution. Below occurred prior to my ownership and all work done by a Porsche specialist with 30+ years experience: 1. Oct 2021 - 76,386 miles - new long block installed with L&N IMS bearing. All useable parts from old motor were re-used on new motor 2. Sep 2022 - 79,197 miles - used DME installed 3. Aug 2024 - 81,649 miles - used transmission installed. Used trans was pulled from another car with 52k miles. 9 liters of Pentosin ATF, new gasket/filter/seal/bolt installed I purchased car in Jan 2026 with 83,013 miles and drove it home 400 miles. Car now has 83,8xx miles. Feb 2026 - drove to DMV and while at DMV, had to shut off car so employee could connect scanner. The car would not turn back on and it was pushed out of the bay. I had car towed home, and after reading multiple posts, I diagnosed the issue as a faulty starter relay which was replaced. I then hooked my cheap OBD II scanner up to the car to check for any other faults and noticed a P0740 code. I reset the code, drove to DMV, passed inspection and drove home. The code returned. I took the car to a local Porsche specialist who topped off the trans with a “small amount” of fluid. This was done for free because they owed me a favor. Now the car is home, and I would like to solve the P0740 issue. I have read all of the tech posts and noticed a few paths including low/dirty trans fluid, Pressure Regulator # 4 and/or Torque Convertor. Also noted, no CEL, a hard up-shift at times between 3rd-4th when trans is cold and local Porsche specialist “won’t touch Tiptronics.” So I’m on my own for now, and I live in Delaware. If you have hung in this long, I appreciate you. Seeing as though the trans fluid/filter was replaced 2,500 miles ago, and just topped off within the past few days, I ruled out low/dirty trans fluid. Remember, the used trans installed in this vehicle currently has 55k miles on in. My question is, how do I diagnose if the issue is with the torque converter (which was not replaced when the new motor was dropped in) or, if the issue is Pressure Regulator #4? Please only post constructive comments. Yes, I can drive a manual trans, but bought an auto trans so the spouse could drive the car as well. Long story behind that lol. Thanks so much for your time and comments!
