glennanddenise
Everything posted by glennanddenise
  1. Dropping your front end is what worked for me. A combination of a lip spoiler, suspension drop is what cured the problem for me.
  2. Sent you a PM. Phillip Thanks for the help Philip - got it in today. No problems.
  3. Hi - I am installing the RSS plenum today and would really appreciate any tips for install. Thanks Glenn
  4. Refined Motorsports in Etobicoke is the guy I trust with my 996. Henry is great. Honest guy that knows his p-cars.
  5. I will be replacing the water pump next week as a result of a leak and seal/bearing failure. Started as a small leak with a whirring sound (as the bearings start to fail). Continued to be a complete failure with massive coolant loss.
  6. Hi Glenn, did the brake light LEDs at least work? Maybe you just have a polarity issue. Other than normal bulbs LEDs need the correct polarity to work right. Thorsten Yes - the LED brake lights worked fine - the center LED just wouldn't light. What I haven't done is switched out the LED brake lights to make sure the LED centre is still operating. May try that this weekend. Tanks for your input. Glenn
  7. Hey wwest - when I put the led bulbs in for my brake lights, my center led brake light no longer worked. Switched it with my stock one and it works. Is this a resistance issue I've heard about with turn signal bulbs? . Complete LED bulb set in my 2001 C4 from V-leds, velocity leds on ebay.com, even markers.
  8. 986jim - did you have any issues with installing the HID kit on a Canadian car? I have heard there were some issues on using an HID kit with Daytime running lights. Thanks Glenn
