Tom Sch
Everything posted by Tom Sch
  1. hi, i have tried this but it seems difficult. is there really no other way to put the chrome plate of?
  2. hi, how can i remove the chrome topcaps from the litronic spray/wash part? i want to paint it separately during installation of a headlamp mask. only pull? any trick? thanks!
  3. hi, nothing happen that could affect the cables! everything is original without any modifications. :(
  4. hi, i have gearbox problems with my 996/2002. shifting is not smooth, every gear change makes a interruption... is there anything to adjust/lube/fix/control on the mechanic from the shifting knob to the gearbox? are there any DIY's or porsche service/maintance instructions available? thanks
  5. hi, i have never seen anything like that before: wracks :o :huh: :(
  6. hi, the problem is that the targa roof is no as stable as e.g. the coupe roof. if you use a lower suspension it is also harder - that will make problems with the glass roof (noise, cracking...). but i don't have heard about a car with broken glass or so... i think if you do your modifications in a "small" (and not to hard) way it will be o.k.
  7. hi, 993 targa mj. 1996 VIN ZTS 08/95-07/96 have sometimes/mostly problems with the glass roof. mj. 97 or 98 VIN ZVS or ZWS have most times no problem! and be careful, don't use a sport suspension or rims with 18" or greater on 993er targa's B)
  8. hi, now i have found a pic of the part i mean!
  9. @Loren the calibration instructions from the service manual are the thing i want too! i have the pcm1 manual by myself. thanks :)
  10. @Loren please can you send me the manual for the PCM1 calibration (and/or other service functions) too!?!
  11. hi loren, maybe i mean this part!?! will this part fit to the original front bumper, without modifications? is there any pic available? thanks
  12. hi, i am searching for a small add on front spoiler (or flap) for the original front bumper 996. in the aerokit XAG should be that part for the front!?! has anybody infos and a pic from that part? thanks
  13. i have also a "date" with the mechanik next week to change the RMS :( Targa 07/2002 22.500km
  14. o.k. i have just ordered spacers with 7mm each side from Albert Motorsport. porsche says that the wheel bolts have to be 8 turns inside, than they are long enough. albert says that some original bolts are long enough - i will see! by the way i will install spacers only on the back.
  15. up to production 08/2002 the PCM 1 was made by Siemens since 09/2002 the PCM 2 is made by Becker exact: PCM 1 radio part made by becker navi part made by siemens assembled by siemens excl. for porsche
  16. hi, i have the "SportDesign Wheel" 10Jx18 ET65 with tires 285/30 ZR 18 on my 2002 targa, suspension is standard. any idea what size of spacers can i add without mod the body?
  17. i have send a mail to Brey-Krause asking about anything to mod the sport seats, here is the answer: Hi Tom, Unfortunately, the only suggestion I have is to install the GT-3 seats. I do not know of any way to safely lower or move the factory seats. I am 6'4" and had the same problem. I used the GT-3 seats because their rounded bottom, mounted with our side brackets, lets us lower the seat right down between the rails instead of on top of them. Dodge :( @umn the porsche seat are produced from a company called LEAR. we (on my working place) made some work on the coming seats for the 997. if all things gone bad i have to ask the guys from LEAR for any idea. the contact to PORSCHE from outside germany may be good, from germany it is really bad for my case :angry:
  18. changing the steering wheel ist no option for me, but i have heard that the company TECHART has a 320mm wheel for the 986/996! Techart
  19. changing parts from the mounts are no problem, changing the seats is no option for me! i write to brey-krause asking about parts for the sport seats. did you have any other idea witch company maybe produces seat mounts for the original sport seats?
  20. hi, in my 07/2002 996er targa i have the "Sport Seats". the seats are great, a little problem for me is the max. adjustment range. i am 202cm (6'8") long and would prefere the seat a little bit more backwards and a little bit more down. is there any chance to mod the seat mounting or any thing else? or ist there any special part available? thanks!
