Kire
    2000 Boxster S, 6spd w/ LSD, 13lbs Flywheel, unsprung clutch, ECU upgrade, Evo Intake, Bilstien Sport Shocks, H&R Springs...
Kire's Achievements
  1. The plugs were replaced about 6k ago,..but the ruff idle was there befor. Also, i only have an issue with starting up right after after i fill up with gas. It starts like a charm all the other times. These may be 2 seperate issues, i only had a problem starting about 3 weeks now.
  2. Congrats on a great car! I, myself have a Speed Yellow 2000 "S" and have done a bunch of mods to it. And not one of them i wouldn't recommend: Evo Intake (Sounds awsome) GIAC Chip, I think? (already had it when bought, unable to confirm though) 6spd w/ Limited Slip Differential 13lbs flywheel, custom organic lined unsprung-disc clutch Eibach sport shocks, H&R Springs, f/r strut braces 18" wheels with some sticky tires plus ruffly 75lbs weight reduction by removing alot of the "fluff" components like a stereo and spare tire.... :clapping: The car flys through the back roads! And shoots off the line. I've gone up against a few 996's and they really can't hang through the corners against a Boxster with an LSD. Gotta love the Mid-Engine!
  3. I have a 2000 Boxster S 6spd that has been suffering from a rough, unsteady idle. My mechanic believes it to be the IACV or a vacuum leak. I did some research and found conflicting info on weather or not there is an IACV in my car,.. I've wrenched many hours on my car and do not see a IACV attached to my throttle body. Does anyone know if my car has this or not? Or any ideas on what may be causing the rough idle? Another issue my car has is when i fill up a new tank of gas my car won't start right away,.. i have to crank it for a few seconds and give it gas when it starts to turn over... not every time does this happen, but more often than not. Any help would be greatly appreciated! List of tried fixes: Cleaned Throttle Body Cleaned MAF Visual inspection of vacuum lines Injector cleaner Fuel filter replace Cleaned air filter Ran a couple tanks of Octane boost and seemed to help a little
