WTL
Everything posted by WTL
  1. I got it through the dealer. Kinda expensive but they let me use 100.00 off coupon. Im going to keep the old one bc the new one is acting strange - there is lag in the map when the car moves and the lettering / font is hard to read at night. Im sorry i did the update and im gong to look in going back to the older one when i have time. The map also seems to "jiggle" when moving..... Drag.
  2. tks.interesting article. Anyhow, drove the car again to verify shaking.... Michelin was nice - talked to them to get some info and they told me to return the tires and get what i had originally asked for - OEM tires. On order.
  3. I recently had the dealer mount and balance 2 new front tires - Michelin Pilot PS2's - 235/35/19's. Please see the attached note on the work order. This past weekend was the 1st opportunity I had to take it out on the highway and i noticed shaking in the steering wheel from about 55 on up and a more noticeable vibrating which seems to be coming from the middle of the car. Called dealer and they recommend 500 miles highway use to see if they settle in. They explained that they have seen some warranty issues on the Michelin's. Can anyone explain the road fore weight statement? Ive never heard of that before and never had problems with any tires,michelin or otherwise. Tks.
  4. tks guys. ill check it out. noticed ill need to remove the front apron. looked for some diy here, but saw none. still looking. tks again.
  5. ok, so I did the update for the maps. but since then, the display when on map has been somewhat of a bad picture. hard to explain, but it seems to be a little jumpy when the car is moving and it makes the map seem distorted a bit. also, night mode is hard to see as well as it was before the update. also, lets say I turn a corner, now it seems the map is slow to male the change with the car - lagging - delay. wondering if anyone sees anything wrong here in this pics, ie, software number, versions , etc. TAGRET is missing a value in one pic. Also, all I did was put in the current map cd for update as the software was already done previously. I did the 2015 dvd. any input appreciated.
  6. So can anyone help - I need a horn replacement and dealer says are 2 of them for my car, a high tone and a low tone. I only see one, to the L of the battery and I dont know the part no. or if there is another?
  7. mystery solved. Inside the leather cd case was this lone cd. I hadn't opened it at first bc all the others were packaged and included outside the case - didnt know there was another inside.
  8. I recently purchased what was/is suppose to be the most current Nav CD for my 2006. The part I was told I need is 997.044.904.51 and what was ordered. Dealer part, came all sealed up with 4 discs - PCM 2.1 Multimedia Update CD Cayene, PCM 2.1 Multimedia Update CD 1 911 Boxter Cayman, PCM 2.1 Multimedia Update CD 2 911 Boxter Cayman and PCM 2.1 Multimedia Update CD Navigation. All CD's have the date stamp 08.2009 while the label on the box has 27 08 2015. Attached is the "new" nav cd and a picture of the older 2013 I had in the car. Why would the box read 2015 and the new cd's 2009? How do I tell what I actual have, a newer 2015 set or 2009?
  9. you probably saw this. while I did not replace anything, this is what happened to me.
  10. 1). So for awhile now, but very sporadically, I get this message " Check front left side light". Asked the dealer some time ago and they say they've seen it before but didnt know exactly what causes it. They say they have checked connections, changed bulbs, etc., but will have the same car continue to have the message from time to time. Any suggestions as to what the issue is or where I can start to look? 2). Awhile back I started to notice around dusk time, when my headlights are on, the dash lights (illuminated background for tach & speed ) and A/C lighting will be bright when car passes under tree canopy's, shadows then when back in a brighter area will go dim. Dimming sensor is picking up the change in ambient lighting during the dusky period causing the dimming to go back and forth. I dont remember it always being this sensitive and am wondering if I have inadvertently adjusted some setting or is this normal behavior or is a sensor going bonkers? Thoughts? Hows yours work? Tks much.
  11. like I said, not sure what made mine start to work again. still no issue with the date and time. BUT, personally, Id be, and am, more pi***d off about all this foam insulation still blowing out of the vents. INSANE!
  12. Sorry, thought I had posted my fix. Dealer 1st replaced gearshift - 997 426 011 02 and still had issue. Then replaced cable 99742603301. Problem solved. They were fair and gave me a credit for the difference - 1st was more expensive. Good luck
  13. Thanks Richard! Actually I never did hear back from the dealer..... Last question - as the latest cd update shows 2015, is there any way to tell if there might be another worth waiting for coming out sooner? Rgds
  14. so I went to the local dealer to inquire on the above - updating to the latest version available for by 2006. They gave me a part no. of 997.044.904.51. But they could not tell me if it would work with my system or if there had been any significant updates to the cd since the one I now have - see picture. Ive read that one must have the latest "B" version software for the 2.1 version. But if I am reading correctly, I now have SW Version 3..... Questions - can anyone please tell me the latest cd map version part no. for my model? am I okay to use the latest cd without anymore updates - am I "current" for the latest map update cd? Tks much. I checked with the service writer and am still waiting. They are stumped for some reason .
  15. Worth a shot seeing as that would be what my guy did I guess. I also noticed yesterday that my radio presets were gone. Possible result of what the tech did. Update after you go out of curiousity. Tks and good luck.
  16. So the date is still in the main display. Very strange as mentioned - the tech said every time he changed it to current date , it would revert back to incorrect date and I had already changed the format once or twice with no effect. Out of curiuosity, do you know if the battery was changed before you bought the car or have you changed it recently?
  17. so the local Porsche of new orleans dealer was nice to offer to look at the car for the date not showing issue. They hooked it up to the computer but could not get the date to stick. The tech was using the latest version. He checked a couple of things and all looked good but when he tried to set the date it would not stick. I was there and saw that the date was still blank. It would take for a sec, then blank out. He offered to unpack an older version diagnostic and said he would try on sat if I went back. I said okay. For the heck of it, on the way back home I decided to change (again) the date format just to see. The date was still not showing on the main display. get home, turn car off. Come in to look online for the latest map disc info - mine's 2013 and the tech mentioned that it may be the latest, so I check online and go back out to the car to get my software version as parts says "Special Note: The new navigation DVD(s) can only be used with software version "B" in PCM 2.1. If "A" software is present, your local dealer may need to update the PCM software (effects 2005-06 cars only)." Soooo, when I turn on the car, this is what I see: The date is back. Guess ill see if it sticks and report back.
  18. I think I figured it out - I actually always changed the clock in the dash when daylight savings came around. after the time was messed up after battery change I also used the dash to reset and it was changing on me. Messing around, I was reminded of the reset option in the PCM in which I then had the right time set but the GMT was wrong.... They noticed that the daylight savings was checked - after changing that and setting gmt to -6, alls well with the time.
  19. I have a thread : in which I had a time issue also after batter replacement. I think I figured it out - I actually always changed the clock in the dash when daylight savings came around. after the time was messed up after battery change I also used the dash to reset and it was changing on me. Messing around, I was reminded of the reset option in the PCM in which I then had the right time set but the GMT was wrong.... They noticed that the daylight savings was checked - after changing that and setting gmt to -6, alls well with the time. BUT now my date is wrong - reads something like 03-12-2000. So now I have a wrong date and dont see that it can be reset??
  20. So I have not looked in the manual yet. But tonight I went to the car and when I started it it had the correct time. The after about 15 seconds it changed to,the wrong time. I did find in the pcm setting where I could change the time. By the time I found it though, the clock had reset itself to the correct time. Funny thing is that I’m on central time and the time setting in the pcm was for New York, gmt -5 even though it showed the correct time for my location, Central STD time. New Orleans is gmt -6.. N.O. Is not a choice so I had to pick Mexico. The incorrect time showed. I had to pick Phoenix, gmt -7 to get central time. I saw no settings for auto update from nav - but like I said I haven’t check the manual yet.
  21. Background..... Have been using until recently Porsche branded battery tender/charger - technically not sure which - plugged into car driver ashtray lighter to keep battery charged. A number of months ago, the unit at the wall plug seemed to be running warm to the touch so I threw it away as it was pretty old. Just left the car sitting using once or twice every month or so.... Then I get a Deltran trickle charger and battery seems to be fine and starts right up... I then get the smart idea to hook up the ring terminal to the battery post so I can just use the quick disconnect. Well, after that the green light(fully charged) on the charger would never light up so I figured the ring terminal was bad. Deltran sent me a new one. In the mean time, I tested the battery and found it low voltage and much older than I had remembered - 6 years. So I get a new battery and just decide to ditch the Deltran and the ring terminal and maybe ill just drive it more often!!! I hope. So, what I am now noticing is that after the battery switch and all the above, I got into the car and noticed the dash clock to have the wrong time so I reset it. Week or so later, I get in the car and the time is wrong again. Thinking I did not set it properly the 1st time, forgot to push the button in - whatever - I reset it again. Another week or so and today I get in the car and it had the wrong time, 12:00 or something... I decide to just leave it alone and drive on. Well, after a few minutes I look at the clock and it had reset itself to the correct time. What gives? Any ideas??? Ive never noticed that behavior before. Tks
