JackTs2K
About JackTs2K
Contact Methods
  • Website URL
    http://
  • ICQ
    Salem, SC
    2007 Boxster
    1965 Triumph TR-4
    1967 A-H 3000
    1993 Corvette
    2000 Honda S2000
    2001 Corvette
    2006 G35 Coupe - mistake
472 profile views
JackTs2K's Achievements
  1. This is from an article on the Planet-9 site. This is being done on a Cayman, but it's still a 987, so it should be the same: 1. Start by adjusting your steering wheel to the lowest position pulled towards you. 2. Pull the trim panel (the one with leather) towards you. It is tight. I circled where you can grab onto. You can slowly pry the sides with a screw driver if your careful. 3. Once you loosen the trim panel you have access to two screws undernieth the gauge. Remove those. 4. Wiggle and pull the gauge pods towards you to remove. The top trim panel stays in place. 5. Remove the connector from the rear of the pods by lowering the locking lever. I did not get an error messages so I think it is safe to remove. Just don't turn on your car until your done. 6. Remove the pods. 7. Remove the 7 screws holding the top trim panel in place and take out the trim panel. 8. Once the trim panel was removed I put the screws back in without the trim to make sure I don't lose them. I'll install the replacement trim panel once Suncoast gets them in. 9. Re-connect the gauge pods. 10. Place the pods in and screw it back in (2 screws)
  2. Go to caymanclub.net and do a search on Borla. There's a very long thread with lots of data re this exhaust. These exhausts fit the Boxster and Cayman. Do a search on Fabspeed or Capristo or AWE or Milltek for some of the others.
  3. Yes, but the clips are $.20 each at a place like Sunset Porsche. That's $1.60 for 8 clips. And if you're just changing the vents themselves, and not changing the vents to Cayman vents, there is no need to remove the frames (where the clips are).
  4. Borla has come out with a pretty slick exhaust system for the Cayman/Cayman S: http://www.borla.com/applications/lookup.a...rsche/Boxster/S. Per Borla, it fits the Boxster S as well. If it fits the Boxster S it should fit the base Boxster, as the exhaust and associated parts are the same, but Borla says it hasn't tried a base 987 yet. I'm hesitant to buy one only to find it doesn't fit correctly, especially since I'll do the install myself. Anyone here try this ?
  5. From JPLV in Nevada: PNA 505 986 Boxster 97-2007 $47.00 USDs + shipping
