kevinbly
Everything posted by kevinbly
  1. Thank you! This helps immensely! I assume this view is of the drivers side of the engine, correct? Kevin B
  2. Hi guys, I have a 2012 958 base with a small coolant leak. Based on the symptoms and that it is a common issue, I suspect it is the notorious thermostat housing leak. I have searched all over online looking for the exact location of this thermostat housing. Can anyone provide some guidance? Can I inspect it from the top of the engine? Or from the bottom? What has to be removed to get to this area to inspect it for this leak? I understand it is supposed to be near the rear driver side of the engine but I removed the engine cover on this side to look for it and I could not find it. Can anyone provide some guidance on where exactly to look? Perhaps with any helpful pics or diagrams? Thank you you for your help. Kevin B
