PBXJedi
Everything posted by PBXJedi
  1. Can you help me out here, I read the following you posted "Multirib Belt / Poly Belt / Serpentine Belt Super easy. 30 minutes or less. I had to buy a 24mm socket and a cheater bar, but the socket was cheap and I've been needing a cheater bar for a while anyway." - can you send me a picture or some simple instructions for changing this, I have access to the eng, just not sure which roller is the one I need. thx! PBXJedi (2001 Boxster S)
  2. Dan, I have the same radio in my '01 Boxster S: It's a CR220 Mod# BE 4362 What code worked for you? Thanks, PBXJedi
  3. SWEET!!!! You guys ROCK! Thanks for the info and the pics
  4. Shawn, It will take a few days for my Bentley repair manual to get here, excellent suggestion thx. I found out how to open the compartment and basically dissemble the incased engine. Would you mind giving me a few steps on replacing the Alternator. I can see it on the left, behind the passenger seat. I believe OEM is 120 amps, any brand would suggest replacing it with, Bosch, Remy etc? Thanks, PBXJedi
  5. Help!! I might have the same problem, I need some advice PLEASE. All, my 2001 Boxster S (3.2, 6 speed) (48K miles) ba :D ttery died about a week ago. Ran to the store bought a new one. Yesterday while driving the following lights came on: ABS, Battery & Air Bag. After about 30 secs they went off and then came back on. I turned the car off, voltage metered the battery to find it hovering around 11+ volts, big drop for a new battery. I started the car, turned everything on (AC, Lights, Radio) and the car totally freaked on me. By that I mean, everything worked in slow motion, check the battery voltage and found it at a staggering 9+ volts and falling rapidly. I’m thinking alternator is going out on me but want the advice of some folks who are fellow owners. And if it is the alternator can someone tell me how hard it is to replace yourself, instructions would be nice. Super thanks!!!! PBXJedi
  6. Radio Code Please (I changed my battery) Year: 2001 Boxster S Engine: 3.2 Trans: M Radio: CR220 Becker1 BE:4362 SN: 15050274 Thanks in advance!!!
  7. Toby, If it doesn't, what should I look for to fix or replace, the remote receiver itself? Thanks, PBXJedi
  8. All, Recently picked up my Boxster S, it came with two keys, so I was thrilled. However, neither of the car remote key buttons work to disable the alarm or unlock the doors/trunk. The batteries are good in both keys, I see the red light flashing when I press the buttons. I can manually unlock the doors and disable the alarm no problem. Is there something I can do to fix this myself, like a re-sync or something to engage the remote option? I would appreciate any feed back. Thanks!!!!
