mdillian3690
Everything posted by mdillian3690
  1. One more thing, is it necessary to put the car on ramps or jack? I know it will make it easier, but is there clearance without? Thanks!
  2. Seriously! Only a couple of dollars at Walmart? What is the tool called?
  3. Is it neccessary to have the tool to remove the oil filter housing? Can it be done by hand or wrench? I am curious? Thanks! 2000 C2
  4. Has anyone attempted to make their own cold air intake, such as the Fabspeed or Schnell? I am curious, I found a website that sells 4 ply silicone hose fairly inexpensive. Not sure if it would work. Does anybody know the dimensions for the hose?
  5. What is the impression on the Schnell Air intake?
  6. Thanks! That is what I thought.
  7. I have a silly question, where is the antenna located for the radio in our cars? Thanks!
  8. Who and how much did it cost to paint your bumperettes? Thanks!
  9. I just found this website https://www.rockauto.com/applet3.html. They seem to have some competitively priced parts for Porsches and other cars. Hope it is helpful to others.
  10. Loren, Thanks! I used some Throttle body cleaner (is that essentially the same as carb cleaner?). by the way, how do I know if I have a egas or non-egas Pcar? I have a 2000 C2 Tip.
  11. Loren, yes at idle. While the car was off, I took off the throttle body boot to check and see how clean the throttle body is and I could swear that the butterfly stays slightly open. For example if you push the butterfly from the bottom inward it will move forward a bit? Is that normal? If not what needs to be done to adjust/correct. Plus, what symptoms could result if the butterfly is slightly open during idle? Thanks!
  12. Hey can anybody tell me if the Butterfly in the Throttle body is suppose to me completely closed flush with throttle body in a closed position or is there slight gap?
  13. Thanks! So it doesn't mean negative things.
  14. Can anybody tell me what type of items fall under a record as far as Carfax is concerned? For example, when you just go to www.carfax.com and enter a VIN it will say, "### records found." Thanks!
  15. I was told it is the same thing www.battertender.com. Not sure what you mean by current running through it?
  16. I just bought the Battery Tender Plus 12volt 1.25amp. Do I just attach the pos and neg to the terminals and plug into wall outlet and there I go? Thanks!
  17. Hey everyone, I stored my P-car and was wondering do you think one of those small plug in cig lighter air compressor will have enough power to put some air in the tires? I found one with 300psi? Thanks! By the way, does anybody recommend putting Fuel Stabilizer (4-5mths storage)?
  18. Has anyone used a trickler charge or Battery Tender http://www.batterytender.com/? I am storing my P-car for the winter and was wondering if these two listed items are needed?
  19. Thanks RoShamBo. That would have been kind of you. Will it damage anything or cause and codes to set? Hp?
  20. Who is familiar with this mod that you can get the cap for free by requesting a sample at http://www.niagaraplastics.com/ The part number is 273-1P Do you call the toll free number? Thanks!
  21. Any pics of the cam solenoid cover?
  22. Hey everyone, I am not to technical inclined, so excuse me if I ask a silly question. But how is it that a stock 996 with 300hp can out perform others with more hp? 0-60, 0-1/4 mile. What is behind the masterpiece of the Porsche? Thanks!
  23. Hey guys, I believe I was in (A) mode, but next time which I hope there isn't one, I will pay better attention. I will try to get on the E-way and test it out. Thanks guys! By the way, what is E-gas?
